Need to add 50 feet cable to the Parallax Infrared Receiver. ( I am using Bs2e)
Hello,
I want to detect an object . And I am using the Parallax Receiver
and the transmitter.
I need to add 50 feet cable between the Basic Stamp and the receiver
but when the distance between the Basic Stamp and the receiver is
more than 15 feet , I can not detect the object.
Questions:
A: How can I increase the signal of the receiver ?
B: I am sending 38500 Hz to transmitter, but
I don't know if the infrared transmitter can work
with 50 feet cable too.
Perhaps 50 feet is to much for both ( the receiver and
the transmitter)
I must not reduce the distance between the Basic Stamp 2e and sensor.
Please, help , I don't know what can I do.
Do you have some information ?
Thanks, Mark
Questions:
the transmitter)
Thanks, Mark
So, your cable now needs:
1. LED-Out
2. DecoderSignal-IN
3. Ground
4. Vin
And your remote board, with the IR-LED and Decoder, needs a 3840-5 linear regulator to drop Vin to +5, and a MAX232 chip with 4 capacitors.
