uoled 96 prop
Hi guys
I have a uoled 96 prop, I have played about with the driveer getting it to display the text I want etc, but I also want to show images from the SD card, I could not find any info on this or code to read a bmp or whatever from the SD card, is there anything about that does not require too much knowledge.
Ive been searching for the last few minutes, I am guessing it uses the put pixel command but how does it read the image and get the pixel info?
DJH
DJH
http://en.wikipedia.org/wiki/BMP_file_format
http://www.rayslogic.com/propeller/3rdPartyHardware/uOLED-96-Prop/RS232Driver.htm
Don't be shy, now!!
Only kidding - you have done some great work - thanks!
