Loading the Asteroids_Demo_13.SPIN on the RAM — Parallax Forums
8Phillip8Phillip Posts: 2
edited 2008-10-21 18:45 in Propeller 1
In chapter 15, page 248, and experiment 3 tells you to load the demo to the Hydras' RAM. I already have the Alien Invaders demo on the EEPROM. When I·try to load the·new·demo,·my TV tells me that there is·no signal coming·from the Hydra any more. What do I do?
  • ColeyColey Posts: 1,129
    edited 2008-10-08 22:28
    Hi 8Phillip,
    I just ran this demo up on my board and it is fine, have you modified the file in any way?
    I just loaded the file and pressed F10 to load to RAM
    Does the first block still look like this.....
    CON
      _clkmode = xtal2 + pll4x            ' enable external clock and pll times 4
      _xinfreq = 10_000_000 + 0000        ' set frequency to 10 MHZ plus some error for xtals that are not exact add 1000-5000 usually works
      _stack = ($3000 + $3000 + 64) >> 2  'accomodate display memory and stack
    Coley
    PS Don't forget that you can't post the code from the Hydra CD / Book, just a word to the wise....
    PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
  • 8Phillip8Phillip Posts: 2
    edited 2008-10-09 19:36
    The programing code looks just like the one you posted. I tried it· again and it still does not work. Could the RAM on the HYDRA be bad?
    edited 2008-10-09 19:54
    not if alien invaders works, on bootup the prop loads any code from the eeprom to ram, then the code is executed from ram.
    have you tried to write a simple program that flashes the debug led?
    Hey Phillip, you ever Asteroids to work for you?
    Paul Baker
