Emic indicating busy constantly after power- up — Parallax Forums
timextimex Posts: 21
edited 2008-10-10 16:50 in General Discussion
My emic module suddenly is indicating busy forever. The red light refuses 2 turn green. PLs need solution urgently.
    edited 2008-10-10 03:19
    There’s not enough information here to really offer you any reply. If I had to guess though, looking at your other thread I would say it is related.
    Parallax Engineering
  • timextimex Posts: 21
    edited 2008-10-10 09:24
    I tried amplifying the sound using an amplifier connected to Aout pin. It worked for hours but stopped working, with the indicator signalling red (busy). Is it possible that the emic module is damaged? I connected another module and I saw smoke coming out.
    Post Edited (timex) : 10/10/2008 9:30:21 AM GMT
    edited 2008-10-10 16:20
    Right, so it seems possible that an error in your circuit has damaged the Emic module. This especially holds true if plugging in another module saw smoke…I would recheck your entire circuit, although it is probably too late for any modules you have connected already.
    edited 2008-10-10 16:35
    It was working very well until I connected an amplifier to Aout pin. I connected 10uF capacitor to Aoutpin and then to the amplifier, TDA7052.
    Is there any precaution I could have taken?
    There’s really no way to know how you have everything connected. I cannot see the circuit to see what might be the problem. It is just a suggestion based on the limited information I have.
