receiving data from Parallax RF Transmitter
Tumbler
Hello,
I try to receive data from the RF Transmitter with visual basic 6.
The data wich is send looks like this:
SEROUT Tx, Baud, [noparse][[/noparse]"UUUU!", strLen, STR string\strLen,crc.LOWBYTE, crc.HIGHBYTE]
The packet data format:
·I use the MSCom component in Visual Basic 6.
In this example i don't receive all data, only a part of it.
The input length from the comm component is set to 0.
Anyone knows the problem here?
' |----------||------------| |------------||-------------||-------------| ' |Data Count||Data Value 1|...|Data Value n||Checksum Low||Checksum High| ' |----------||------------| |------------||-------------||-------------| ' BYTE 1 BYTE 2 BYTE n+1 BYTE n+2 BYTE n+3 ' ' Byte 1 consists of the Data Count. The Data Count is a value from 1 to 16 ' representing the number of Data Values in this packet. Packets can ' contain from 1 to 16 bytes of data values (at least 1 Data Value is ' required). ' Byte 2 through Byte n+1 are the actual Data Values where ' n = Data Count+1. ' Byte n+2 and Byte n+3 are the last bytes in the packet and consist of a ' 16-bit Cyclic Redundancy Check (CRC) Checksum value calculated using the ' bytes 1 through n+1 together
Private Sub commRFG_OnComm()
Dim sData As String
sData = commRFG.Input
Text1.Text = Text1.Text & sData & vbCrLf
End Sub
- Stephen
I found out that my settings of the comm control are wrong, that's why i only receive the first 8 bytes.
The sended data is correct. These are packages with variable-length data (from 1 to 16 bytes)
Package looks like this:
first the preamble ("UUUU!"): This gets the receiver "in sync" mode
byte 1: the length of the package
byte 2: data begin
byte n+1: data end
byte n+2: checksum (low)
byte n+3:checksum (high)
