Question for the Gurus. Current Sensing
At work we have a back up 30 KVA backup generator that is supposed to start with an automatic transfer switch when the power grid goes down.· It has only been in place for about a year.· It is supposed to be execized on a monthy basis.·· anyway...· long story to get to the point.· A month ago, the generator didnt start.· Fortunately the janitor called me to let me know the power was off.· When i got there the unit said that it exceeded it cranking time.· I gave it another try and it started right up.· So we have now installed a monitoring system.· This system monitors the grid, generator and load.· To do this, all that is installed is a simple little device that is zip tied to the large conductors.· It was explained to me that it is like to little device that you can get a home depot to tell if a wire is hot by touching the insulation.· It was a great idea.· Any idea how to make one of those?
It's Only A Stupid Question If You Have Not Googled It First!!
Looks like i am wrong. it senses voltage. http://www.toolup.com/greenlee/gt11.html this is similar to what i was explaining.
I am looking at a Hall Effect Sensor. Sould this work? and if so, do these require that i break the circuit and feed it in and out if the chip?
For long term use, you'll probably need to parallel the batteries with a power supply of some sort. To obtain a signal for external logic, break the circuit of the indicating LED and add an optocoupler in series. The output of the 'coupler can be used for the external circuitry.
To the original problem, the genset might be able to be set up to try a couple of more times after an over-crank. After all, the genset is designed for emergency service and shouldn't give up so easily! If it already has multiple re-tries enabled, the system needs to be looked at to find out why it didn't start.
Cheers,
Tom Sisk
http://www.siskconsult.com
Brian Carpenter
Tom Sisk
The one s·that have I seen you do not have an option to have it start·more than once with out reset it
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 10/7/2008 12:38:46 AM GMT
I like this small Zap series·- http://www.ampsolution.com/
Donnie
Those are great. i bought 2 to play with
I have made progress. I will post my results in the prop forum since i am using that chip.
Donnie
