noisy power affects PLL
I'm sure this has been covered before, and I'm sure it is mentioned in the manual, but I have recently started using a new 3.3V regulator for my prototyping boards and while assembling a new device I wanted to test something on it and couldn't figure out why nothing was working. I eventually figured out that my new regulator (while averaging 3.33V -- according to a voltage meter) was actually quite noisy and consistently alternating between 3.1V and 3.5V (according to an analog oscilloscope). With an external 5MHz crystal, PLLX8 worked fine, while PLLX16 seemed to prevent the propeller from even booting properly. I couldn't get anything to function at the highest PLL. Just by adding a 1µF cap on the power it seemed to operate, but the power was still not smooth. At about 20µF, the power seemed completely flat; just to be safe, I will use at least 100µF (especially once I get more power sucking components on the board), but I have oodles of 470µF caps, so I will use those. Hope this helps someone!
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I use an LM317 for the 3.3V supply on my (homemade) Propeller PCBs and don't have any problems.
Leon
