SX-Key Access Problem — Parallax Forums
edgellmhedgellmh Posts: 85
edited 2008-10-06 08:00 in General Discussion
When I attempt to debug a program I get the message "SX-Key not found on COM6. It used to work.
The SX-Key is plugged into a USB port and the Windows system tool tells me that port is COM6. Also doing programming seems to sort of work. By sort of what I mean is that the reason I want to debug is that some of the very simple code I have created and loaded into the SX chip doesn't execute as expected. Because of that I have recently removed and then re-downloaded the SX-Key IDE version 3.2.3 and the SX/B version 1.51.03. When I fire that newly loaded software up it does not take me through the startup configuration screens.
marshall edgell
