Tilt sensor confusing accelerations with tilt
One of the threads states that you need to ramp up the commands on a hill climbing boe bot (using the MEMSIC tilt sensor) so that it does not confuse hard accelerations with tilt.· But if the Stamp can do only one thing at a time and the Boe Bot seems to stop instantly when the wheel commands stop, how would this happen.· It looks the Boe Bot stops instantly when the wheel commands end.· Then it takes a measurement from the sensor.· So I do not seem any way they could be confused unless you are running two stamps one with the sensor and one for the navigation commands.· Am I off base on this?· Will the Boe Bot keep accelerating after the wheel pulse commands stop?
- Stephen
http://forums.parallax.com/showthread.php?p=522967
-Stephanie Lindsay
Editor Parallax Inc.
P.S. - The Stamps in Class text "Smart Sensors and Applications"· has in-depth activities for the Memsic Dual Axis accelerometer for both tilt and acceleration. You can dowload it free from its product page.
