Need a wireless serial cable solution.
Is there any product to wirelessly replace a serial cable that is going from a PC com port to an Sx chip project? I know that Parallax makes the receivers and transmitters which is ok for the sx end but on the transmitting end I would like something more in a completed box or module with a db9 connector that I can connect the PC to. Ideas or comments?
http://www.parallax.com/Store/Education/CustomKits/tabid/134/txtSearch/bluetooth/List/1/ProductID/41/Default.aspx?SortField=ProductName%2cProductName
Any bluetooth adapter should work on the PC side. These can be purhased at most consumer electronic stores (even wal-mart).
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
This is for my Display sign/clock. I currently have it in my living room and if I loose power (rarely) to the clock (DS1302 based), it needs to be reprogrammed by a laptop via Hypeterminal with the correct time and date (text file). This means I need to bring my laptop out to the living room for this which is probably still the cheapest cost effective method. Since my desktop and laptop is in the bedroom (<30 feet), I was thinking of doing it wirelessly. That's all.
Thanks for the good idea.
https://www.aircable.net/catalog/product_info.php?cPath=28&products_id=37&osCsid=l32kordp82j6cakapocdq09b47
Thanks for the good input!
http://www.a7eng.com/products/bluetooth/productpages/eb501-ser.htm
If you have this wireless connection available and your computer is online you could try setting up a scheduled task to push out the current time on a regular basis. Referencing an NTP server to keep your PC's time in sync will help ensure that you always see the right time on your display.
It might take a little work to setup at first but after that it you shouldn't have to worry about it.
Robert
All good ideas guys!
- Rick
On the eb501 module at your display panel all you need to buy if the module and antenna. Just wire it up the 5v logic level serial to your SX processor and just tap off existing power from your display if it is available. That way you won't even need an extra power cube.
This is exactly what I used on one of my robots and it works out great! It was in the May, 2008 issue of SERVO magazine. Since I originally bought two of these modules the second one is going on another robot....
Robert
Does anyone know if there is any sort of additional programming that needs to take place to use a battery backup? I saw something once on trickle charging or something that made me think of this. Perhaps it is in my DS1302 coding, is why simply adding a watch battery to pin 8 did not get it to work too.
- Rick
