Weird Behavior — Parallax Forums
Weird Behavior
edgellmhedgellmh Posts: 85
edited 2008-10-05 01:50 in General Discussion
Things have been going well and I have been writing more and more complex programs until suddenly the behavior of the components on the PDB board no longer seemed to follow my code. I assumed my SX had been burnt out and purchased a new one but I am still getting weird behavior. I removed the SXkey software and loaded a new one along with the new SX/B. I still get weird behavior. If I use the code below the LED on the PDB hooked to RB.0 comes on for a while and then goes off for 2 seconds and then repeats. That is the LED does not do its 4 short blinks. If I replace the HIGH, LOW commands with one TOGGLE command then the LED behavior is as I expect it; two blinks, 2 second pause and then repeats.
Something must be broken but what?
marshall
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
ID "LED"
' IO Pins
LED_PIN PIN RB.0 OUTPUT
' Constants
' Variables
j VAR Byte
' INTERRUPT
ISR_Start:
ISR_Exit:
' RETURNINT ' {cycles}
PROGRAM Start
' Program Code
Start:
Main:
FOR j = 1 to 4
'DO
HIGH LED_PIN
PAUSE 500
low LED_PIN
NEXT
'LOOP
PAUSE 2000
GOTO Main
  • mojorizingmojorizing Posts: 249
    edited 2008-10-04 21:53
    Nothing is broken - you need a "pause 500" after the "Low Led_Pin"
    Bad spellers of the world untie!
  • edgellmhedgellmh Posts: 85
    edited 2008-10-04 23:39
    Well, that was stupid of me.
    How about trouble shooting the code below.
    FOR j = 1 to 4
    'DO
    LED_PIN = 1
    PAUSE 500
    LED_PIN = 0
    PAUSE 500
    NEXT
    If I use HIGH or LOW for either one of the lines the code behaves as I expect it. But when I use the code above the LED never lights up.
    marshall
    edited 2008-10-05 01:44
    marshall,
    It works for me in either case.
    HIGH LED_PIN·and Low LED_PIN
    or·
    LED_PIN = 1 and LED_PIN = 0
    I'm using SX-Key v3.2.3
  • JonnyMacJonnyMac Posts: 9,616
    For me, too (see attached). Beware sloppy coding/formatting -- this is an easy way to hide errors.
