powering a servo
hi, i need to power a micro-servo from a 13.5v DC line. i take it that the 13.5 would fry the servo.
what should i use to step down the voltage? a plain 7805? or something like a switched-mode reg(please provide an example part number).
Thanks in advance for any replies
Lee.
Lee.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I've run up to 5 standard-sized servos through a 7806 being fed ~13 volts w/o thermal shutdown.
from what ive read, a micro servo can draw, anywhere between 180 and 340mA operating under no load.
the servos i want to use(cheap esky EK1-500's) arent listed anywhere as far as i can tell.
would 500mA cover it?
EDIT: referred to the wrong guy(said leon, meant zoot).
Post Edited (Lee Marshall) : 10/4/2008 12:07:42 AM GMT
That said, the best thing to do really is just measure the current draw of the servo -- then you'll know. In theory my standard servos draw up to 1100ma each from stall, but when I measure all 5 starting at once, as a total set they were drawing less than 1.75amps, and less than half that running.
You can also get regulators in TO-3 cases which require a larger heatsink and can handle much more wattage, but at that point a switching regulator might be in order.
You can get integrated switching regulators with a 780X series pinout (single board, ready to use) for about $15, e.g., search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=PT78HT205V-ND
i have built and PCBd a prototype circuit, and it is currently working. the firmware is incomplete, but i have 2 servos moving to a preset position.
the actual application is a set of miniature 'robot' lights which use high intensity LEDs(REALLY HIGH) to project onto a semi-transparent silk-type material suspended above the front garden in the dark.
the effect being "ghosts" flying around. this halloween is gonna be awesome.
I'm going to use a computer to send commands to each light unit(distributed around the front of the house) via a 19200baud one-way serial link in a multi-drop bus setup. the framerate will be 20Hz.(each unit receives 20 commands a second)
the problem is that each light unit needs power.
i measured the current of the servos, and it hits about 250ma when moving.
would there be a problem with using a 3-core cable with 13.5VDC, GND, and SIGNAL, as the "bus" for the light units?
i am worried that the fluctuations in current would smoosh my signal up if if they are in the same flex.
the signal is to be 0-5V to be fed directly into each microcontroller's UART. could i just use a max232 as a driver for all of the unit's UARTs(there will be about 5 light units in all)?
any thoughts?
Post Edited (Lee Marshall) : 10/8/2008 1:01:44 AM GMT
