What do you use to solder on?
Hey guys,
I don't do a tremendous amount of soldering, but when I get into projects I tend to do them on my work desk instead of a formal soldering station. I'm looking for a small soldering mat that can protect my desk from burns and scratches from boards and components.
What do you use to protect your desk, if anything?
Seriously, something that might work great is one of those burnproof silicone pads used on cookie sheets.
My desk is going to become a cheap desk if I don't find a solution.
Ken
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
There's nothing like a new idea and a warm soldering iron.
I have access to several sheets of cardboard, so when one starts to looks cruddy, it is replaced.
Besides, having a large cardboard surface also allows you to write notes on your desk while you work.
Cheap and double featured.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
- Stephen
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Properties: cheap, non conductive (I use to test circuits on the same board), warm and comfortable, pcbs dont slip over the board, durable, easy to clean...
to catch anything on fire.
I use a cookie sheet... if i ever need to apply power to something I slip some cardboard in as an insulator... although fire is
a hazard that way.
I suspect you're talking about a (brown) pressed board with only one smooth side. If that's the case, the name which we usally associate with that product is Masonite®, although many manufacturers make it.
Bruce Bates
When all else fails, try inserting a new battery.
Tracy Allen
www.emesystems.com
paper, T-square, triangles, and ERASERS.... a drawing board was required equipment.
Basically, this was a wooden board 1.5'x2' or so. Ever since I left school that's what
I've soldered on. Dunno, with CAD systems and all being the tools of trade for drafting,
if such drawing boards are still available or not.
Besides, getting cookies has a higher priority to me so...
-Rusty-
Rusty Haddock <=> AE5AE
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Sometimes I'll set down paper or cardboard on the bench if I am going to be soldering a lot of boards. Why might you ask? Well after doing a lot of soldering I find that the flux may otherwise find itself all over the bench. Usually cleans up ok with regular rubbing alcohol but with the paper/cardboard you just roll it up and throw it away when your done. That might be a good (and cheap) solution to working at your desk.
Robert
I really want a PCB vise though...
Whit+
Need to get some servos on them connected to a Microcontroller and get them to do the work for you!
Robert
Whit+
Sounds like you need to make a trip to Ikea! They have just about every item mentioned above. That's what I use to solder on, a cheap Ikea desk.
-Parsko
sometimes a desk, sometimes a kitchen table, sometimes i just hold the board in my hand.
Gas soldering irons are useful.
i have an iroda solderpro 50.
