Need a recommendation — Parallax Forums
CannibalRoboticsCannibalRobotics Posts: 535
edited 2008-11-04 19:45 in Propeller 1
I have been unable to get my head wrapped around where a variable lives in the prop and how it is most efficiently referenced/modified from multiple cogs. Can someone recommend a good tech note on this aspect of the architecture/language.
Jim-
    edited 2008-10-03 17:39
    Hi Jim,
    You need to be a little more specific with your request, are you talking about intraobject or interobject, are you talking about assembly to assembly, assembly to spin, or spin to spin?
    Paul Baker
    edited 2008-10-03 18:12
    Hello Jim.
    as long as all cogs are started by cognew from the SAME *.SPIN-File
    you can access them simply by the name of the variable
    here is a demo which shows that
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    VAR
      long heart_stack[noparse][[/noparse] 20]
      long CogStack1[noparse][[/noparse] 20]
      long CogStack2[noparse][[/noparse] 20]
      long MyTestVar
    OBJ
      'heart : "heartbeat" little object from the obex making an LED blink so i can see Prop is working
      debug : "FullDuplexSerial"
    PUB Main
    'the FIRST PUB-Method inside a spinfile is ALWAYS the startpoint where the program starts to run
      'heart.Start(27, 200)
      debug.start(31, 30, 0, 9600)
      MyTestVar := 100
      debug.str(string("Start MyTestVar="))
      debug.dec(MyTestVar)
      debug.Tx(13)
      cognew(M1,@CogStack1)
      cognew(M2,@CogStack2)
      repeat
        waitcnt(clkfreq + cnt)
        debug.str(string("MyTestVar="))
        debug.Tx(13)
    PUB M1
      repeat
        waitcnt(ClkFreq * 3 + cnt)
        MyTestVar := 1
    PUB M2
      repeat
        waitcnt(ClkFreq * 5 + cnt)
        MyTestVar := 2
    if you want to access variables ACROSS different objects
    define the variables in your top-object-file
    and pass the ADRESS of the variables by using the "@"-operator (the adress-operator
    VAR
      long MyVar1
      long Pointer_to_MyVar1
      long MyVar2
      long Pointer_to_MyVar2
    OBJ
      MyObj1 : "MyObject"
    PUB Main
      Pointer_to_MyVar1 := @MyVar1
      Pointer_to_MyVar2 := @MyVar2
      'then give the value of the pointer to the other object as a parameter
      'of some kind of setup-method to the other object
      MyObj1.Start.....
      MyObj1.SetupPointers(Pointer_to_MyVar1,  Pointer_to_MyVar2)
    now INSIDE the file MyObject.spin
    there have to be variables for the pointervalues
    VAR
      long Ptr1
      long Ptr2
    PUB SetupPointers(p_Pointer1,  p_Pointer2)
      Ptr1 := p_Pointer1 'through this setup you can use the pointers in every PUB or PRI-method inside THIS object
      Ptr2 := p_Pointer2
    'and then you can access the variables inside THIS object by
      long[noparse][[/noparse]Ptr1] := ....
      long[noparse][[/noparse]Ptr2] := ....
    best regards
    Stefan
    heathclf,
    What you've posted seems unnecessarily complicated, like why are you using pointers?
    You've got the simple case of a method (subroutine) that is running in its own cog with everything together in one object. Good!
    Here it is simpler:
    VAR
    Byte stack1[noparse][[/noparse]30], highTime
    CON
       maxHigh = 1200*80
       minHigh = 975*80
       totalTime = 20000*80
       servoPin = 0
    PUB main
       highTime := maxHigh
       cognew(PulseServo, @stack1)
       repeat until highTime < minHigh
          highTime := highTime - 100
    PUB PulseServo | myTime
    'This assumes that the pulseis going to an inverter (for 5VTTL conversion), and so the timing is reversed
       dira[noparse][[/noparse]servoPin]~~ ''Output Pins
       repeat
          myTime := highTime   ' reference it once so, if it's changed between the waitcnt's, the timing will still be correct
          waitcnt(totalTime - myTime + cnt)
          outa[noparse][[/noparse]servoPin]~
          waitcnt(myTime + cnt)
          outa[noparse][[/noparse]servoPin]~~
    Post Edited (Mike Green) : 11/4/2008 7:50:32 PM GMT
