battery backup for the boe
hey can someone tell me if I would be able to connect a 9 volt power supply for continuous power to my board of education, but also have a 9 volt battery connected to my board of education at the same time?
The reason is so when the power goes out, my stamp will remain usable on battery backup.
However I was concerned that this may cause the stamp to be powered by 18 volts due to the 9 volt power supply and 9 volt battery connected at the same time.
I need to know if the stamp will only use one power source at a time or if the voltages will double and if my idea above will work.
Chris.
Chris.
For in much wisdom is much grief, and he who increases knowledge increases sorrow." ~Ecclesiastes 1:18
http://www.walmart.com/catalog/product.do?product_id=3910294
With the low power drain of the single 9v power supply, you should be able to get a fairly good run time when its on battery.
·If you put a diode in the + line from the 9V power supply and and one in the + line from the battery (this means you'd need to use a battery connector with leads that you can cut inhalf, not plug it right onto the board clips),···· Then whichever is more positive would power the board, but not be able to backfeed the other source.
If your 9v power supply is a quality one and·regulated at 9v (as opposed to a wall wort that runs higher but drops under load), you should add a second diode (possibly 2) in series in the battery lead to be sure that the power supply voltage·is slightly higher than the battery when measured at the board.
