Dynamixel AX-12+
Hello there!
I am wondering if it is possible to control this powerful servos with the propeller chip at his max comunication speed 1Mbps.
I have been looking for a solution and I have only found the next solution:
http://www.crustcrawler.com/electronics/propeller/docs/ConnectingBASICStampToAXDynamixelBus_Rev1.2.pdf
the problem with it is that you need to use a BS2 and a Propeller chip.
post all the information you can please
Make sure you browse through the Propeller Object Exchange as well in case a driver has already been contributed.
http://www.crustcrawler.com/electronics/propeller/index.php?prod=17
