Amplify volume from emic module
Hello, every1.
My emic module's volume is not loud enough for the project I'm implementing. Can any1 please help me out. I need a functional amplification circuit. Thanks
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
Leon
Audio output buffer pin provides a single-ended analog output of the
synthesized speech for external amplification. Drives a minimum load of
5k Ω up to a maximum of 1Vp-p. The AC signal is superimposed on
approximately 1.2VDC bias and must be capacitively coupled to the
load.
If you read the datasheet for the TDA7052, the sample circuit shows a load of 5K.
So, you need to capacitively couple Aout to pin 2 of the TDA7052. I'd use a 1uF to
10uF 8-10V minimum electrolytic with the + end to Aout. I'd put a volume control
between the electrolytic and pin 2, like a 5K or 10K trim pot with one end to ground,
the other end to the electrolytic, and the slider to pin 2 of the TDA7052.
I'm sure others may have better ideas, but this is what I'd start with.
Leon
