FullDuplexSerial object — Parallax Forums
stefstef Posts: 173
edited 2008-10-01 13:26 in Propeller 1
Hi
I'm using the FullDuplexSerial object to minitor 4 serial connections in the background. I start every connection in a new cog.
I was wondering, bacause thier are more pins on the propeller, how menu serial connections I could monitor wit 1 propeller. How do jou do it when you run out off cog's or is it an other object to use for that.
I would like to monitor 10 rs485 line's, translate what is comming in and send it out on a rs232 to the computer. Sommething like a protocol converter. Has someone experiance with that?? or can someone advice me on the tought.
Stafan
Post Edited (stef) : 9/29/2008 8:01:39 PM GMT
  • stefstef Posts: 173
    edited 2008-09-29 19:03
    sorry subject forgotten.
    stefan
  • TeslaTesla Posts: 55
    edited 2008-09-29 19:09
    RS-485 is multi-drop. Could you just use one line and get away with it?
    edited 2008-09-29 19:34
    You can add a subject by clicking the pencil icon to the top-right of your message. Take care.
    Parallax Engineering
    edited 2008-09-29 20:03
    Hi
    Yes I know it is multidropbut the rs485 is comming from different machines and has already the maximum adresses occupied for the protocol used. That is wy I need to combine them. Thier is a master on ietch line that don't like it if it is connected to the other line with an other master.
    I tried to set up a littel connection with my demo board and it is working.
    That is why I was wondering now how far I could go with one propeller.
    Stefan
    edited 2008-09-30 13:41
    Hello Stefan,
    funny to have another forum-member with the same prename.
    There is a Multiple serial port driver object in the obex
    obex.parallax.com/objects/340/
    it serves four ports within one cog. So 5 cogs would be just enough to make all 32-IO-Pins
    to serial ports
    4 cogs receiving 15 ports and 1 cog to send it out again
    It think with this driver it is possible to increase the buffersize. Like it is with FullDuplexSerial
    Stefan, if you finished this project. I think parallax would be very interested in presenting your project.
    As it show very good what a propeller is able to do what most other chips can not within ONE single chip
    best regards
    Stefan
    Hi
    Yes we have the same name, but that can't be bad.
    Thanks for the advice. I will look into it.
    stefan
