Displaying Text and Decimal numbers reflected or backwards. — Parallax Forums
Frank70Frank70 Posts: 6
edited 2008-09-30 16:34 in Propeller 1
Has anyone been able to display text & decimal numbers reflected on a tv display or monitor?
I am trying to reflect a display, therefore the info on the screen has to be reflected or backwards.
i would appreciate any input on this problem.
Thanks, Frank
    edited 2008-09-28 21:41
    hello Frank,
    in the Prop-manual page 32 is a description how the characters are defined.
    With that it should be possible to turnaround the bitpattern
    best regards
    Stefan
  • RinksCustomsRinksCustoms Posts: 531
    edited 2008-09-28 22:59
    With respects to the Hydra manual, this isn't possible with the internal ROM font, (or near impossible). However, a bitmapped "reverse" font is very possible and would be easy to implement, providing you have the memory for a bitmapped font. The ROM font uses an equivalent of the total main memory, 16,384 KB (calculated). You could use less space than that if you omit all the special characters like schematic symbols, special language characters, and any other non-needed characters.
    E3 = Thought
    http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
  • tpw_mantpw_man Posts: 276
    edited 2008-09-28 23:38
    You MIGHT be able to modify the TV driver to read from right to left so anything you do using the default TV driver will show a mirrored image.
    I am 1011, so be surprised!
    Advertisement sponsored by dfletch:
    Come and join us on the Propeller IRC channel for fast and easy help!
    Channel: #propeller
    Server: irc.freenode.net or freenode.net
    If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
    edited 2008-09-28 23:47
    It is possible but it will require modification to the assembly driver. When the long is loaded frrom the character map you perform a REV on the data which will flip it. You will also have to modify the color table to redistinguish the character. The character map is interleaved (refer to the manual which does a good job explaining this) and they are teased apart into the individual·character through the color map. If the color map were left as it is a chronological steping through the character map whose values are REVed would produce BADCFE instead of the desired ABCDEF. The color map should have the 4 colors in each color entry (LONG)·reversed (0,1,2,3 to 3,2,1,0).
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 9/29/2008 12:06:57 AM GMT
  • RaymanRayman Posts: 14,825
    edited 2008-09-29 02:01
    Well, I'm planning on rotating the ROM font 90 degrees for a project...
    Haven't actually done it yet...
    But, the plan is to copy the ROM font into HUB RAM and then bitwise manipulate it to be rotated.
    Then, it's pretty easy to change the base address that the display routines use from that ROM font to the RAM one.
    Backwards is even easier because the two tiles used by a character are the same...
    As RinksCustoms points out, I would only do the first half of the font to save space...
    One trick to keep in mind is that the new font probably has to be 16 long aligned, but I do this all the time for custom graphics tiles...
    Post Edited (Rayman) : 9/29/2008 2:07:40 AM GMT
  • Frank70Frank70 Posts: 6
    edited 2008-09-29 02:39
    Thanks for all the ideas. I will try them sometime this week when I get a chance.
    Tanks again to all.
    edited 2008-09-29 13:25
    Actually, now that I think about your particular question... Paul's idea of inserting a REV instruction in the driver and reversing the colors would save a ton of memory...
    I've thought about my advice and I think that the color mapping should be from 0,1,2,3 to 0,2,1,3 since a bit reversal (00->00, 01->10, 10->01, 11->11) instead of flipping all of the color values.
    Paul Baker
