FullDuplex <-> linux (over FTDI) blues — Parallax Forums
pemspems Posts: 70
edited 2008-09-29 14:29 in Propeller 1
Messed with it all day to no avail, so came here for help
trying to use FullDuplex object to send data to a host PC with my app listening on the serial port that the FTDI chip (which is in the propplug) provides.
using 9600 8n1 and usual settings to initialize the serial port on linux.
The general problem that i am experiencing is the app getting too few / too many bits in some bytes it receives, which totally messes up the data flow.
i've tried to isolate the issue, so i did the following: sending from the prop either 0x0f or 0xf0 one by one. The result on the app end is 0x0f for 0x0f (ok) and 0x70 for 0xf0 (looks like it reads too many zeros - 5 instead of 4, i.e 00000111 instead of 00001111 , where LSB is on the left)
Am i missing anything?
Thank you
  • AribaAriba Posts: 2,695
    edited 2008-09-28 02:04
    Sounds like a Baudrate problem.
    Have you set the CLK-settings in the Top Spin object?
    for a Protoboard:
    CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    Andy
  • pemspems Posts: 70
    edited 2008-09-28 03:39
    Thanks Andy, i did (used the top object from some example)
    very small progress on the above: managed to get receive my 0xf0's properly (receive 0xf0 instead of earlier incorrect 0x70)
    Simply had to flag-out the following option:
    options.c_iflag &= ~ISTRIP;
    this option seems to allow the serial port to actually receive the extra bit(s) as opposed to cutting a byte short (hence 0x70 instead of the proper 0xf0)
    but i am still experiencing loss of bytes occasionally
  • BradCBradC Posts: 2,601
    edited 2008-09-28 04:41
    I usually use
    stty -F /dev/ttyUSB0 raw -echo
    If you are actually writing code, then
    c_cflags = CLOCAL | CREAD | BAUD
    zero all the other option registers..
    Pull my finger!
    edited 2008-09-28 14:42
    Thanks a lot Brad, you gave me a very good hint: zero out all the options. I am guessing some flag left enabled in options was giving me problems
    Here is a little serial setup recipe i am using - no dropped bytes yet hop.gif
    tcgetattr(fd, &options);
    // clear all options
    options.c_lflag &= 0;
    options.c_iflag &= 0;
    options.c_oflag &= 0;
    options.c_cflag &= 0;
    cfsetispeed(&options, BITRATE); // where BITRATE is defined as something like B115200
    cfsetospeed(&options, BITRATE);
    options.c_cflag |= (CLOCAL | CREAD);
    options.c_cflag |= CS8; // i think this is needed to tell linux how many bits to use for data
    // Set the new options for the port...
    tcsetattr(fd, TCSANOW, &options);
    fcntl(fd, F_SETFL, FNDELAY); //no blocking
    edited 2008-09-29 09:54
    Ahh, you must be on a BSD derivative.. yes.. that's the way to do it.
    On Linux you need to OR the bitrate constants against options.c_cflag.
    Also you probably don't need the FNDELAY as that is generally used on IP sockets.
    You need Block/nonblock for serial hardware, but don't go setting nonblock unless you are doing select() on the FD properly or you _will_ lose data.
    Pull my finger!
    Nope, ubuntu 8.04 here
    the example i started with is some example off the web. I don't want it to block because i don't want my UI, that's in the same loop, to be sync'ed to these blocks. I want it to be fluid, so i'm fine with just polling the serial port.
    So far so good, with no dropped bytes (i even tried 460800 baud successfully)
