Nested Float32full code
How nested can the float object be?· Will this cause problems?
example:
xl:=fp.fround(fp.fadd(fp.fmul(fp.cos(plrad),3.0),64.0))·····
·- Ouch, thats not suppose to be hot!··
Michael King
Application Engineer
R&D
Check out Project: PSAV Persistent Sailing Autonomous Vehicle
example:
Michael King
R&D
Go your hardest! (or until you run out of stack anyway)
Pull my finger!
I have this problem where everything works fine until i run one of my methods that are called manually then the method will run for the thirty seconds it is suppose to run then when I try to go to another method it won't go! There is alot of math there. Then it calls a Fullduplexserial (comm.str) in a different method but it won't work.
Michael King
R&D
You do keep mentioning about things not working sometimes. You're welcome to vent your frustration, but the problem is likely to be one part of your program scribbling on another part of your program and the kind and amount of information you're providing isn't the sort of thing that will produce an explanation or a fix. Slow and methodical debugging will likely work.
