Unwanted blink in LED's
I am trying to dim up and dim down some led's. I used the following code
' {$STAMP BS2}low
' {$PBASIC 2.0}
Counter VAR Word
Full VAR Word
Full = 2310
·Pulse
FOR Counter = 0 TO Full STEP 15
PAUSE 5
PULSOUT 9,counter + 1
·NEXT
FOR counter = Full TO 0 STEP 15
·PAUSE 5
NEXT
·GOTO pulse
The Led's are powered thru a ULN2003A driver·
I does what I need however as the led's get to their full brightness there is a small very short but noticable blink.
Q: Does anyone know why and how do I remove it?
Post Edited (GTV61) : 9/26/2008 5:23:44 PM GMT
' {$STAMP BS2}low
' {$PBASIC 2.0}
Counter VAR Word
Full VAR Word
Full = 2310
·Pulse
PAUSE 5
·NEXT
·PAUSE 5
NEXT
·GOTO pulse
how you've got everything hooked up it probably blings when it goes back to the start
of the program. Perhaps a capacitor in there someplace to help hold the charge for just a
bit would stop the blink???
Oh, and someone is going to tell you to edit your subject (put a subject in)·
Prune Free.
You didn't say what kind or how many LEDs your powering, But I think your useing the Vishay Telux Ultra Super Brite LEDs Part# TLWW9900 or simular,If so;These LEDs are current hogs, Yes I said Power Hogs,They need a TON of current to reach full illumiation.While I don't think it is brownin out the $stamp, It could be·putting the ULN2003A into thermal overload for a brief few mSec.s.I would check the current draw @ the Vdd/Vss pins on the ULN2003A to see if its overloaded @ peak output...
This is all I can offer w/ the info. you gave
$WMc%___out
Post Edited ($WMc%) : 9/28/2008 12:54:54 AM GMT
Try this to see if it helps?
Just a thought.
' {$STAMP BS2}low
' {$PBASIC 2.0}
Counter VAR Word
Full VAR Word
Full = 2310
·Pulse
PAUSE 5
·NEXT
' keep output 9 high
high 9
·PAUSE 5
NEXT
·GOTO pulse
Dave W.
message if I don't use a colon after the address name (pulse).· I don't know if this will help...
eliminate that possibility in your troubleshooting.
