is it compatible
I have a BS2 , and it appears I have cooked the outputs P1 through P4.· They just don't operate... although i can use the same code by changing the outputs from P1,2,3 and 4 to P 5,6,7,and 8 ,· and P 5·thru 8 operate OK.
If I replace the BS2 with a BASIC Stamp 2p 24-Pin Module, is it ·interchangable with the BS2 in every way, except that it runs faster?
WHile I am on the subject, I used some H11A optoisolators to isolate the load from the BS2 ( apparently too late) it's kind of a pain with the resistors and whatnot... is there an easier to use opto Isolator, maybe that already has series resistors .... and while I'm on that subject is there an LED that is already resistored for 5 vdc
thanks
thanks
There are some LEDs that have built-in series resistors. RadioShack sells one. They're not commonly used.
If you use an SSR (solid state relay), these usually have a built-in series resistor and will operate over a wide range of input voltages.
I don't want to seem like I am hijacking this thread, but I too am having similar problems.
I mentioned in a previous post that I was waiting on the arrival on a BS2px24. It arrived today. I had been using a BS2 and the BOE. After installing the new controller, I ran 'Identify' and only the 'Loopback' and 'Echo' columns showed data (both YES). Also the correct COM Port was showing. I tried running some simple code (of course, I ensured the BS2px Directive was used) and the Stamp was not found.
Thanks, and please let me know if I broke any forum rules.
Deus tantum me iudicabit
Do you have a recent version of the Stamp Editor?
Make sure the BS2px is powered.
Make sure your new module is inserted properly in its socket.
@realolman
The BS2e is a drop in for the BS2 and has some nice features that you can use later (SCRAM and program slots)
@servello
Did you try moving where the USB cable plugged into your computer? I have an external hub, and I had to move the cable to a dirrect USB port for it to work.
No.
Version 2.4 - I believe this is current.
Since the BS2px is installed into the BOE, isn't it just a matter of supplying power (9v in this case) to the board?
I saw no bent pins or anything like that. And it was oriented the correct way.
I have 3 usb ports on my laptop. Do you mean I should try using one of the other two ports?
