H-Bridge Circuit
Thanks for all the help guys that you've been giving on my line following robot.
So, I've finalized a lot of the parts of my robot and I just wanted an opinion of the·attached circuit.
I think everything's good in the circuit except for·the inductors that are attached to the H-bridge (L298). I read somewhere online once that if I were to use a inductor in series with an H-bridge's GND or VCC (for Motor) pins that the inductor would keep the current constant in the circuit. However, I can't simply blindly include them because the PIC microcontroller (http://www.pololu.com/catalog/product/210) is going to be applying a 600Hz PWM frequency to the H-bridge... so the inductor might build up a considerable impendence at that frequency.
I'm just being to learn this stuff right now in college and I'm kind of new to actually understanding exactly how analog circuits work.
Should I nix the inductors or keep them?
---The current sensing outputs on the bottom are at the bottom of the H-Bridge are included so you can atttach a series resistor to sense the voltage across the resistor and then calculate the current through the resistor and thus the motor. I'e put inductors there instead.
Nyamekye
Post Edited (Kye) : 9/25/2008 5:01:11 PM GMT
Nyamekye
- Stephen
Parallax Engineering
Nyamekye
