PIR sensor distance connection?
I'm dealing with some "teenage" issues and need to know
when my front door (or porch) is in use. I'm thinking of
using a PIR sensor to a remote propeller board.
Question: What is the max distance I can put between
the connection of the PIR to the propeller? Can I put
20-30 wire connection (twisted pair) without losing
accurate signal?
May just have to unroll some cable and try this today.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
accurate signal?
OBC
I would go ahead and wire it up as if there were no problems to be expected, but with a mindful eye on what could potentially go wrong and devising an effective way to diagnose any issues, and a solution for it in your back pocket if needed. A simple multimeter should be all you need, measure the voltage on the line, the current on the line and the current on the ground. EMI could be a little more difficult to devise a good test for. If you see issues in your measurments, then it's time to incorporate some solution to combat this.
Paul Baker
JMH - Electronics: Engineer - Programming: Professional
Post Edited (Quantum) : 9/25/2008 5:12:51 AM GMT
