Propeller Tool v1.2 more insistent about missing drives
Phil Pilgrim (PhiPi)
Versions of the Propeller Tool before 1.2 have always complained upon startup about missing drives when, for example, it had seen a digicam memory card before that's not there subsequently. This was easy enough to dismiss, just by clicking Continue a couple times, and the minor annoyance would go away.
Version 1.2 is a different beast, though. Not only is it necessary to click Continue more times to make the modal dialog go away, but it keeps popping up again at odd intervals, even when the Propeller Tool is not in the foreground. (It just popped up again as I was typing this paragraph.)
I'm wondering what changed and whether that could be taken as a clue for how to eliminate the problem altogether.
[noparse][[/noparse]Update by Moderator]· This problem has been resolved: please download Propeller Tool v1.2.5 for the fix.
http://www.parallax.com/tabid/442/Default.aspx
Post Edited By Moderator (Jeff Martin (Parallax)) : 12/6/2008 1:20:47 AM GMT
So, it occurred to me that I could simply delete drive E: from the list of drives in the left panel:
(And why are they duplicated?)
But it won't let me delete drive E: without having something in drive E:. Go figure.
'Still some PropSTICK Kit bare PCBs left!
This fix (or hack) by obc worked for me.
Thanks for the reminder! I had forgotten about OBC's post but recall now, when I first saw it, thinking my problem wasn't severe enough to be messin' with the registery. But having gone from Irritation Level Yellow (annoyance) to Level Orange (nuisance), OBC's fix was definitely called for. And it worked! Thanks, OBC!
But it's not as weird as my Vista losing its view settings for a folder [noparse];)[/noparse]
Last night I got the biggest icons I have ever seen on my Vista [noparse];)[/noparse]
Why doesn't Propeller Tool drop the drive when I tell it to ignore the error? Other software drop the error after I have clicked ignore.
/Henrik
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
Perhaps I should post that on Wiki so it doesn't get lost.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
