first newbie assembly program. — Parallax Forums
darkxceeddarkxceed Posts: 34
edited 2008-09-25 16:34 in Propeller 1
Hello,
First I like to thank deSilva and potatohead's nice assembly tutorial.
Even is potatohead's tutorial was simple, I still learn't things.
Now my first program will be a sort of capacity meter.
I first load a capacitor with a pinout(in serie with a resitor ofcourse).
Then I set the same pin to input and wait till the the capacitor drops below the treshold of logic "1".
I then want to fill an array with measured data, this will al be done in assembly.
A program in spin will set the array size which the assembly program will fill with measurements if it is 'called'.
Below is the program in assembly:
pub Main(value)
· cognew(@Toggle, value)
dat
·········· ·· org 0
Toggle··· ·mov dira, #$1···················· 'set pin 1 output
············· xor outa, #$1···················· 'set pin 1 high
············· mov Time, cnt···················· 'copy system counter to Time
············· waitcnt Time, Delay············· 'wait a small delay.
············· mov dira, #$0···················· 'set pin 1 as input
:loop····· ·mov Pin, ina····················· 'copy value form pin 1 to Pin
············· xor Pin, #$1··· wc··············· 'look if Pin value has changed from 1
············· if_nc jmp #:loop················· 'loop while 'c' is "0"
············· mov TotalT, cnt·················· 'copy system counter to TotalT
············· sub TotalT, Time················· 'substrac Time from TotalT
············· wrlong value, TotalT
'defined data
Delay········ long 20
'ungedefined data
TotalT······· res· 1
Time········· res· 1
Pin·········· res· 1
value······· res· 1
Now I want to know what the difference is between the 'defined' and the 'undefined data' except that it already has a value?
Why not make all the data defined, and I guess they are all in cog memory because I can only read and write data with wrlong and rdlong(ofcourse also the word and byte).
Please can you give me your opinion about my programm, maybe there is something wrong or good [noparse]:)[/noparse].
  • hippyhippy Posts: 1,981
    edited 2008-09-23 17:14
    Note ...
    mov Time, cnt 'copy system counter to Time
    waitcnt Time, Delay 'wait a small delay.
    That's going to be around a 50 second delay. You need something like -
    mov tmp,cnt
    add tmp,delay
    waitcnt, tmp,...
    For "cognew(@Toggle, value)" you need to pass in the address of whaere the 'value' variable is "cognew(@Toggle, @value)", and when it comes to returning a result ...
    You have the registers reversed, and where you will be writing to ( ultimately the Spin 'value' variable ) has its address held in PAR, so ...
    wrlong TotalT,PAR
    As to the difference between initialised and uninitialised, anything with 'res' doesn't take up space in hub memory / Eeprom image so saves space. If you had 100 registers all initialised with "long 0" that would take up 100 longs ( 400 bytes ) of Hub / Eeeprom. If each were defined as 'res 1' no space would be taken up, but what they were initialised with would be 'random values'.
  • TimmooreTimmoore Posts: 1,031
    edited 2008-09-23 17:19
    Also value needs changing to a VAR variable. It currently only exists in the cog memory so spin is passing an address of somewhere invlid in hub memory.
    edited 2008-09-23 18:00
    Also ...
    xor Pin, #$1 wc 'look if Pin value has changed from 1
    if_nc jmp #:loop 'loop while 'c' is "0"
    You'll probably need to use 'test Pin,#$1 WC" there.
    Plus, after you've returned your result using 'wrlong'; what next ? The code execution just continues into 'nothingness'. You'll need a 'jmp #...' to re-run the program or to stop it doing anything else ( 'jmp #$' ), or a 'cogstop' to close the entire Cog down.
  • darkxceeddarkxceed Posts: 34
    edited 2008-09-23 19:31
    hippy said...
    Note ...
    mov tmp,cnt
    add tmp,delay
    waitcnt, tmp,...
    wrlong TotalT,PAR
    Ah yes I forgot to add the value for the waitcnt, the 'delay' in my case will be added after the waitcnt operand.
    If I define a value[noparse][[/noparse]1000] in spin and use the cognew(@Toggle, @value) command.
    When starting with wrlong command, it will start at value[noparse][[/noparse]0] then value[noparse][[/noparse]1] etc... ofcourse I have to skip 4 bytes every time.
    But what happens if I go to value[noparse][[/noparse]1100]?
    nothing or will I overwrite some code in the hubram?
    I don't understand 'wrlong TotalT, PAR', TotalT has a number that will be placed at value[noparse][[/noparse]0] for the first time.
    How do I let the propeller know that PAR is the place for value[noparse][[/noparse]0]?
    As for the res and other variables, the 'long' is hubram and the 'res' is cogram?
  • tpw_mantpw_man Posts: 276
    edited 2008-09-23 19:44
    The long is still cog ram, it just exists as data in hub ram. The PAR register gets loaded with the second value on a cognew. So cognew(@asmcode, @value) sets PAR to @value. Note that par is only 16 bytes with the lowest 2 bits zero, so all your addresses have to be long aligned in hub ram.
    I am 1011, so be surprised!
    Advertisement sponsored by dfletch:
    Come and join us on the Propeller IRC channel for fast and easy help!
    Channel: #propeller
    Server: irc.freenode.net or freenode.net
    If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
    edited 2008-09-23 21:16
    But what happens if I go to value[noparse][[/noparse] 1100 ]? nothing or will I overwrite some code in the hubram?
    The stars go out, time stops, and the universe gets sucked into a black hole. Bad things happen - Yes, code ( though more likely other data ) will be corrupted and cause no end of problems. Don't forget that with "VAR value[noparse][[/noparse] 1000 ]" you can only access "value[noparse][[/noparse] 0 ]" through to "value[noparse][[/noparse] 999 ]" ( not entirely true to be a pedant, but the stars go out, time stops, etc unless you intend to do this and have catered for it ).
    I don't understand 'wrlong TotalT, PAR', TotalT has a number that will be placed at value[noparse][[/noparse] 0 ] for the first time. How do I let the propeller know that PAR is the place for value[noparse][[/noparse] 0 ]?
    That comes from the "cognew(...,@value)"; the second parameter is placed into PAR when the PASM code starts, so what PAR holds is the address (@) of 'value'. The 'wrlong TotalT,PAR" says put the value at the location indicated by the address held in PAR. In spin it's the equivalent of writting -
    PAR := @value
    long[noparse][[/noparse] PAR ] := TotalT
    which becomes "long[noparse][[/noparse] @value ] := TotalT", thus, "value := TotalT"
    Both are in Cog RAM. Cog RAM the only thing within a Cog which can be accessed other than through the rdlong and wrlong instructions.
    But in addition "long" will also be in Hub RAM but RES will not be ( for the sake of simplicity ).
    edited 2008-09-24 17:36
    Ok after some work I figured the sample below out.
    Could this be working?
    con
    ·_clkmode = xtal1 +pll16x
    ·_xinfreq = 5_000_000
    VAR
    long A[noparse][[/noparse]1000]
    pub Main
    · cognew(@Toggle,@A)
    dat
    Toggle······· mov adres, PAR
    first········ mov dira, #$1···················· 'set pin 1 output
    ············· add Time, #90····················· 'small delay
    ············· waitcnt Time, Delay·············· 'wait a small delay.
    loop········· mov Pin, ina····················· 'copy value form pin 1 to Pin
    ············· test Pin, #$1······ wc··········· 'look if Pin value has changed from 1
    ············· if_nc jmp #loop················· 'loop while 'c' is not·"0"
    ············· wrlong TotalT, adres············· 'write value of TotalT @ pos '0' of hubmem
    ············· add adres, #4···················· 'add 4 to adres which points to PAR
    ············· djnz Size,#first················ 'substract 1 from Size and if not '0' jump to first
    'defined data
    TotalT······· long 0
    Size········· long 512
    'undefined data
    Adres········ res· 1
    edited 2008-09-24 17:56
    you need to do something after djnz, after 512 times round the loop, it falls through djnz and is executing whatevers in memory. either do a cogstop or a loop e.g. stop jmp stop
    edited 2008-09-24 18:13
    Hi Tim,
    When I want to stop the cog, which instruction must I use?
    Cogstop(@Toggle)?
    or stop it with
    Cogstop(cog~ -1) in spin,·I will have to make a small endless loop at the end of the assembly code.
    Is it possible to let the cog start @Toggle while it is running in the small loop at the end of the assembly withought stopping the cog.
    This will ofcourse be faster that when I want to load the cog with instructions to start.
    edited 2008-09-24 18:44
    3 options
    1. In asm after djnz
    cogid Adres ' store cog id in adres
    cogstop Adress ' stop this cog
    2. In asm after djnz
    stop jmp stop
    in spin change cognew to id := cognew
    then work out when cog is done and call
    cogstop(id)
    the 1st is easier and you dont have to work out when the cog is done - though you need to anywhere to know when you can use the data in A
    3. Change the asm so it loops, i.e. after djnz
    mov Size, #512
    jmp Toggle
    this will keep reading, filling up A and then reseting back to the start of A and filling again
    The program below is what I have now.
    Questions remain:
    'PinSet' it sets·pin 16 as output, it has value $10001 I guess. But wil other pins be unchanged because is defines pin 16 as 'out' and the rest as 'in'?
    This also counts when I set pin 16 as input, all the pins will be set to·input, but only 16 has to be set as input(rest must be unchanged). And does the line "Test PinSet,ina·· wc" works? It·must look if pin 16 goes low·, else repeat loop.
    dat
    ············· org 0
    Toggle······· mov adres, PAR··················· 'copy hubmem adres to 'adres'
    first········ mov dira, PinSet················· 'set pin 16 output
    ············· mov outa, PinSet················· 'set pin 16 high
    ············· add Time, #40···················· 'add 40cycles to wait
    ············· mov dira, #0····················· 'set pin 16 as input
    loop········· test PinSet, ina······ wc········ 'test if the pin input goes low
    ············· if_c jmp #loop··················· 'loop while 'c' is not "0"
    ············· djnz Size,#first················· 'substract 1 from Size and if not '0' jump to first
    ············· mov Size, #511
    ············· jmp Toggle
    ············· fit 496
    'gedefined data
    Delay········ long 40
    Size········· long 511
    PinSet······· long |<16
    'Mask········· long $10001
    'ungedefined data
