Propeller Ham Radio
I am kinda new to the propeller chip and everything. I bought it to make a robot with, but in the process of learning spin, i found out that it has some great features that could be used for Ham Radio. I succesfully built an AM transmiter with it, as well as a cw keyer that works in the HF range.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The Propeller is not fast enough to do this over a wide band of frequencies. You could use the Propeller at IF frequencies.
It could also be used to generate SSB, again at IF frequencies. It would be a demonstration of concept rather than a
practical device, mostly because of noise.
You can only address noise through careful design of software and hardware. This is not received noise from outside the system.
We're talking about internally generated noise within the receiver / transceiver. Adding a signal processor just adds more noise
and losses.
I don't have a link to the thread ... Just go through the threads for the last week or so. It's a bit of work, but you also might
find out some other interesting things.
Leon
