Bug in map2spin.exe (Andre!)
NOTE: This is mostly for Andre.
I recently was using map2spin.exe, and all of a sudden it kept on giving that feared 'Sorry, but this application has encountered a problem and needs to close' message. It stops at the _tile_bitmaps LONG line, which makes me think maybe the image was invalid. I did create the images in a Macintosh image editor called Pixen. I then exported it as a bitmap, opened it in Paint, saved it as a jpeg, and saved the jpeg to a bitmap, which makes one think it should clear up any compatibility issues. It crashes at the memcpy() in the Extract_Bitmap function. I am not fluent in C or C++, so any help identifying the problem, in either my data or the program would be appreciated.
Attached are the two culprit files, ran with no flags whatsoever.
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Channel: #propeller
zip
643B
What is it exactly you want? do you want the something that converts that map file into a spin data file that you can cut and paste into your project file?
if so, let me know and I'll knock a quick app up for you?
or is it the BMP you need converting?
Baggers.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
Channel: #propeller
Channel: #propeller
edit: checked it this time, downloaded and upzipped the file and opened it·[noparse]:)[/noparse] as for the initial bmp, don't know why that didn't work [noparse]:([/noparse]
Post Edited (Baggers) : 9/26/2008 7:32:54 AM GMT
Channel: #propeller
Channel: #propeller
do you want an app making up?
if so, let me know what format you need them in, ie what tv driver are you using?
Channel: #propeller
Will have a look again later ;P
Channel: #propeller
That's very strange, if you want, you can zip up the project and PM it to me, and I'll fix it for you? if you want that is.
Baggers.
PS. Also, on a side note, you do realise by using the HEL drivers you won't be able to release source code for the HEL drivers for this game.
