Proto board pin fanout
I'm wondering how other people use the Propeller Proto board.
Maybe I'm overlooking something, but to me the "Large prototyping
area" is nearly useless for mounting IC DIP packages. Once you've
soldered a chip in place, you can't attach any other wires to the
same hole. Most other project boards have short bus strips (2-3 holes)
for each IC pin.
So, how do you do it? (Probably I'll feel really dumb when somebody
explains it to me!)
for each IC pin.
explains it to me!)
The IC and the discrete parts are lightly soldered into their holes before doing the wiring. Just enough solder is used to mostly fill the hole.
I will also do some wiring on the bottom of the board the same way, just not running the wire through the adjacent hole first.
Also, when you mention fanout it is slightly misleading since that term usually refers to how many other chips (which vary by type) the electrical output of a pin can drive. I think we figured out what you were asking for anyhow.
Best Regards,
Robert
Similar to http://forums.parallax.com/attachment.php?attachmentid=52122 but note that puts the pins horizontal to how one normally views the ProtoBoard whereas vertical is IMO best for mating with strip-board.
It means that you can move the ProtoBoard to whatever strip-board project you're working on and doesn't dedicate that ProtoBoard to a specific task. Having 'messed-up my first ProtoBoard' by adding too much clutter and causing re-work damage, this is how I'd now do it.
but I didn't know if there was a better way!
Hippy, that's a good idea to use Molex strips and make the Proto board reusable.
I'll probably give it a try, too.
