Motor choice and encoder choice. — Parallax Forums
KyeKye Posts: 2,200
edited 2008-09-25 00:32 in Robotics
Hello,
I'm trying to build a line following robot and I'm having a hard time deciding what type of motor to use. I'm using the BASIC Stamp 2 as my brains and it will be able to update the robots speed, direction, etc. about 10 times a second - which is adequate.
Anyway, the problem is that I need so way of making the robot move pretty fast because it will be in a line following race. However, I need some position feedback control and other environmental control except where the line is because the course is on a sloped hill with two severely sloped drops in which the robot will most likely accelerate greatly.
So, my current options are:
I have a 1.5A dual H-bridge to drive the motors (geared up ones)·with current sampling and constant current control, however I think I might need some kind of encoder for speed feedback. However, any encoder I use will need to have its own separate co-processor because I can't devote time from the BASIC Stamp to maple motor speed data.
I also could just use two servos. But I don't know if they will resist acceleration and be fast enough to get me through the course the fastest.
I'm trying to cut cost - current I'm working with a robotics club that has a load of old servos and old motors and other electronic equipment - that being said I don't wish to buy too much stuff.
So, any ideas? Does anyone know which type of motor to use?·
Thank you for your help,
Nyamekye
    edited 2008-09-20 19:29
    Motors and encoders probably will give you more speed. Do some Googling to find out what is available. If you have a specific question ask. Use what you got if you want to save money.
    - Stephen
    edited 2008-09-20 23:18
    Interesting variation to have varying slopes in a line-following event where the robot may coast downhill faster than you are trying to drive it. You have so many design variables that you won't be able to anticipate what it will do before you build it and test it: how heavy is the bot, where is it's CG, do your tires grip without slipping, wide rubber band tires or narrow o-ring tires, motor/geartrain selection, coasting/dynamic braking, etc.
    If you know you will experience 3-D terrain, you want adequate (but not excessive)·ground clearance and a 3-point suspension (ie, two-wheel differential drive and a single skid/caster to avoid loss of traction by one drive wheel lifting up.
    The Stamp is "single thread" and can only do one thing at a time, so encoders would require more processing power. I would pursue a solution without them and spend most of your time on positioning, reading, and interpreting data from·your line sensors for highest vehicle speed.
    My·suggestion is to forego encoders entirely and·use worm drive gears on your wheel drives instead of traditional spur gears.·See·http://www.pololu.com/catalog/product/69·· and http://www.pololu.com/catalog/product/73.·Although they are not as efficient power-wise, they are self-locking and will not coast when your motor is switched off, even if torque from a steep downhill is applied. Of course, your wheels can always slip in an extreme case, but all is lost at this point anyway and encoders wouldn't help. Alternatively, use a standard gearbox with a very high gear reduction ratio to reduce the downhill torque effect. See a good selection at http://www.pololu.com/catalog/category/34, some of which can be assembled in several various gear ratios, including one already set up for differential steering: http://www.pololu.com/catalog/product/114.
    In general, smaller/lighter/simpler is better when speed is the goal. Have a look at the tiny new 3pi robot from Pololu. Info & vids at http://www.pololu.com/catalog/product/975
  • DJSandbergDJSandberg Posts: 56
    edited 2008-09-21 04:12
    Kye,
    Take a look at the Wheel Watcher.
    http://www.nubotics.com/products/ww01/index.html ·
    It's an encoder that you can put on a servo and a plastic Boe Bot type wheel.· They also include some sample programs for the Stamp and most other controllers so it's very easy to use.·
    You can take the electronics out of servos and run them as gear head motors at pretty high voltages, like 12 volts.· They tend to blow up or melt at around 14 volts.·· Lube the gears well.
    Daryl
  • TimmooreTimmoore Posts: 1,031
    edited 2008-09-21 05:40
    I have used some of the same motors that pololu use on their 3pi
    http://www.pololu.com/catalog/product/993
    and they are fast! I used them with these wheels http://www.pololu.com/catalog/product/1090 and they have a tooth system inside the wheel designed for a sensor see http://www.pololu.com/picture/view/0J813
  • KyeKye Posts: 2,200
    edited 2008-09-24 23:19
    Ah thanks for the help. I want to use the worm gear box and I still may. However, I purchased the high speed gear box from Tamiya already and I think it will do the job. I have till April to complete my robot, so I will have plenty of time to fix any problems.
    Nyamekye
    Please delete your other message ... the one with no subject. In the upper right hand corner of the message, there's an X icon. Click on that.
