Memory
I was wanting to know if anyone could tell me how to address multiple eeproms with out using a large amount of i/o lines and without using an i/o expander.
I appreciate any and all feed-back that is provided.
Cheers,
Simon
www.norfolkhelicopterclub.com
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again
BTW: I type as I'm thinking, so please don't take any offence at my writing style
Thanks for you quick response.
(x)eeprom+(Y)eeprom=(x+y)eeprom
an eeprom of (x) size wired in series with and eeprom of (Y) size will create the same thing as a single eeprom of combined (x) and (y) size
Thanks for answering my question.
Here is a quick question if you guys don't mind.
Is their a limit the that amount of eeproms that you can have in series?
Ultimately there probably is electrically although that number can likely increase if the I2C operating speed is reduced and the bus interface designed to suit.
The biggest limitation is in addressing the separate Eeproms in series which more likely than not renders any electrical issues moot. With three Eeprom address lines on the chips (A2,A1,A0) you can have eight Eeproms in series. Using more I/O lines and some clever address connections you can push that higher.
this depends on the number of adress-pins
usually are three adresspins which is 2^3 = 8 adresses
You can see this in the datasheet of the eeprom
There are some more possabilities with different BASE-adresses of the chips
if you want to use that you have to control the adress in your spin-code
But i don't know anything about the details
I think it will be easier to use one BIG EEPROM instead of 1-16 smaller ones
or if you are thinking about more than 512kB to switch over to an SD-card which could be up to 2GB big
best regards
Stefan
