serial coms
Hi
I have been looking round for a very simple way of reading and displaying an RS232 serial output and displaying the data string on a small LCD screen.
I have to admit have not been getting very far.
The best idea I can come up with is to use a basic stamp or PIC to grab the input and then send it to a small LCD.
Basically we have a 'black box' style data recorder that is only controllable via a pc. Data is output via 232 and at this time only readable with a pc. This is not good out in the field even with a laptop. So I need a small box with a serial input and a screen. Baud rates 4800 and data is an ASCII string approx 20 characters CR LF at intervals from 30 secs to 5 mins.
can anyone point me in the right dirction
cheers
cheers
Here is a link to a software datascope program which is trialware. It will do everything you have asked, and much more:
http://www.win-tech.com/html/demos.htm
Look near the bottom of the page for Listen32.ZIP.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/50/Default.aspx?SortField=ProductName%2cProductName
Jeff T.
Thanks for the pointer to the software.
Sadly I have got numerous serial monitoring and data logging s'wares, all of which require the use of my laptop in the field.
When I say field I mean field, usually middle of nowhere, rain beating down, wind blowing a hooly.
Not the best place for my laptop. So I am trying to downgrade to a very simple, basic, no frills, wysiwyg plug in and display unit that is so cheap that it wont matter if it gets dropped in a puddle.
Thanks again. and the Listen32 stuff looks quite good.
hydro (Graham)
Jeff T
Thank you for your time. You have verified what i was thinking. It will give me a reason to start learning the way of the BS2.
I shall research and then probably be back here with loads more questions
Ceers
Hydro( graham )
