I made a stupid — Parallax Forums
I made a stupid
M. K. BorriM. K. Borri Posts: 280
edited 2008-09-17 04:50 in Propeller 1
I made a major stupid, and misdesigned a pcb -- basically I have a OV6620 camera with the Y lines feeding into the propeller's first i/o pins.
Problem is, they're backwards!
So now I have Y7 going into pin 0, Y6 going into pin 1... Y0 going into pin 7.
In assembly, how would I swap the bits?
http://forums.parallax.com/showthread.php?p=650217
meow, i have my own topic now? (sorta)
    edited 2008-09-17 03:20
    Use the REV instruction. It reverses the specified number of least significant bits in the destination register and zeros the rest.
  • M. K. BorriM. K. Borri Posts: 280
    edited 2008-09-17 04:05
    so I'd go
    rev IMadeAStupid, #24 wr
    and that's it? one asm instruction?
    wow.... lucky me @_@
    thankyou so very much.... will try it!
    Yeah, one instruction ... only 50ns at 80MHz.
    The "wr" is on by default. Shift instructions always write the result unless "nr" is specified.
