multipul outputs
I have written many programs and every one i had send a high or low signal to multipul pins. my question is simple, can I tell two different pins to go low or high in one line. For example: I want pins 1,5,9, and 13 to go low. The way i have been doing it is with 4 lines of code. is there any way to consolidate it. I have attached an example of the way I am doing it now. If someone could tell if this is consolidatable. If so where can I find the information on how to do it. I have been looking for a while and have no clue what im looking for or where to find it.
I light up·everyones life!!!!!
You don't separate them, you use them in groups of 4, 8 or 16 pins as required. It's merely a matter of logically assigning consecutive physical pin ports when you do your wiring. Once you've done it, you'll never turn back.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
outl =%11011001 would make pins 1,2,and 5 low all others high
outh does the same, but addresses pins 8 through 15
if you wanted to address 4 consecutive pins you would use :
outa for pins 0 through 3
outb for pins 4,5,6,7
outc = 8,9,10,11
outd = 12,13,14,15
In any event, we can't help you figure out what's wrong without a posted copy of your source program. If it's short, use the [noparse][[/noparse] code ] [noparse][[/noparse] /code ] brackets to include it in your message (without the extra spaces). If it's long, attach it to your message using the Attachment Manager.
