Prop output to tiny speaker
Hi All,
I need a tiny sound producing device which will only be 'beeping out numbers' for very short period of time. (Ie, 42 = beep beep beep beep, wait, beep beep, wait)
I came across the PUI 'SMT-0540' (Digikey 668-1192-1-ND) which seems suitable but I have a few questions because it is electromagnetic.
Do I need to put anything between the +ve input to the device and the prop output pin?
Also, im assuming to make a sound I just need to send whatever frequency out of the prop pin ive connected it to?
Sorry for all the silly questions, im used to devices with internal drivers but there arn't any this small [noparse];)[/noparse]
Alec
-Alec
My our page
Alec
-Alec
My our page
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Good idea [noparse]:)[/noparse] Here it is. Sorry theres not much to it, this is all I could find for the time being.
-Alec
My our page
Any sort? Or does it need any specific specs to make it suitable? Im hoping theres something in the SOT-23 package...
EDIT: Just clicked. Is the reason for the trans due to the current requirments exceeding what the prop can give out of 1 pin?
-Alec
My our page
Post Edited (Basil) : 9/16/2008 4:27:40 AM GMT
The circuit shown in the attached diagram should drive the speaker you selected. In the circuit diagram the speaker is modeled as the 12 Ohm resistor R3. The speaker sees approximately 50 mA peak drive current. If you want to drive the speaker closer to it's rated 100 mA, simply change resistor R2 to something like 27 Ohms. Remember the speaker must be driven with 4000 Hz +/- 500 Hz as stated in the data sheet. Most any NPN switching transistor should work in-place of the 2N2222 part shown.
You might want to search for a small SMT Piezo transducer or buzzer. They can be driven directly from a pin and consume far less current. Beware though, Piezo transducers typically resonate in a narrow frequency range, so you might want to try "sweeping" your frequency to find the sweet-spot where the output is loudest.
Good Luck, David
Post Edited (Drone) : 9/16/2008 7:35:05 AM GMT
I have had a good look for a small piezo/buzzer but couldn't find one small enough
-Alec
My our page
Graham
Thanks & Regards, David
The diode should be rated for at least 500mA. If the Propeller pin that drives it remains in a high state, the transistor and speaker could get very hot. So try to avoid that situation. If in doubt, capacitively coupling the input can be used during debugging to prevent burnout.
'Still some PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 9/16/2008 5:44:23 PM GMT
Those little piezo speakers can be modeled as a simple capacitor. They can be driven by a unipolar source (i.e. 10Vpp is +-5V, so 3.3V unipolar is fine). A typical values is ~15nF. You could connect one leg to ground, and the other leg via a 2k resistor to a pin on the prop. The 2k would limit the maximum current output, and the RC circuit ends up as a ~6kHz lowpass filter. You could just drive the single pin using the standard duty-cycle counter mode and play waveforms or whatever you desire.
lonesock
Piranha are people too.
lonesock
Thanks for the input people [noparse]:)[/noparse] That answers my question perfectly [noparse]:)[/noparse]
Alec
-Alec
My our page
Alec, when and if you find your best solution for the small noise maker, please share it with us.
Rgds, David
EDIT: Datasheet attached. I know 68db is not loud, but it only need to be heard from a few meters away anyway [noparse]:)[/noparse]
-Alec
My our page
Post Edited (Basil) : 9/16/2008 10:38:34 PM GMT
Neither the BS170 nor the 2N7000 have a low enough VGS(on) to be of much use with the Propeller. The transistor I spec'd can sink significant current with a VGS of 2.5V.
You are right about the NMOS parts I cited; my-bad. The FDV303N is a nice part, I wish it were available in TO-92.
Alec,
Have a look at Mallory P/N AST1109MLTRQ (DigiKey P/N 458-1093-1-ND). The Mallory part has the same dimensions and footprint as the CUI part you cite but with 5 dB higher SPL and one-fifth the current at rated output. In unit qty. from DigiKey they're $2.82 USD ea. ($1.28 qty.-1k). You may find it cheaper elsewhere.
Regards, David
Thanks for that. Will have a look at that one [noparse]:)[/noparse] same footprint is nice because I have already cramed my board as much as pos :P
-Alec
My our page
