sd card size
Hello
what is the largest size sd card that a propeller board can use. if it cant use 4gb is there anyway to petition the sd chip into 2 2gb
Badger
Badger
SDHD but I have not tested that.
thanks for the info.. i found a 4gb cheap before i did research so hmmm .. i will see if i can get around this some how..
Badger
http://forums.parallax.com/showthread.php?p=746666
You can read SDHC cards, but there is still the FAT16 2GB limitation if you want more than raw access.
lonesock
Piranha are people too.
