Power problems
Hey guys,
What would happen if I try to connect an additional LM7805 5V+ regulator to the Vdd pin of the basic stamp?
Basically, I need some additional power for a line follower robot with·an a regulator to fix the problem associated with battery voltage drop. Since the basic stamp already has a 5V regulator will an external regulator and the basic stamp's 5v regulator work together?
I've been reading online that the one with the lowest voltage will actually try to source all the current and the other will do nothing, so if that were to happen I would exceed the power draw of the on board regulator of my basic stamp.
Thanks for your help,
Nyamekye
Nyamekye
Normally, you divide up the items that need +5V regulated current. Some of them get connected to the output of one regulator and the others get connected to the output of the other regulator. The outputs of the regulators are not directly connected together. The inputs to the regulators are connected together.
It is possible to connect several regulators together, but you have to follow the manufacturer's recommendations. These may vary from one type of regulator to another, whether there's just a requirement for a minimum output capacitance or you need small series resistors for current sharing.
So, if you connect it to Vdd, you'll get nothing. If you connect it to Vin, you should be able to get another 1.5 amps out, assuming the wall-wart or transformer driving it with 6 volts can supply that much current.
You'll probably get better replies if you move this topic to the robotics section.
Nyamekye
You can add a second regulator to work together with the stamp's regulator. You have to connect the extra regulator to Vin
not Vdd. See diagram below.
Adrian
Parallax Engineering
