COM# help — Parallax Forums
COM# help
LilaLuLilaLu Posts: 2
edited 2008-09-15 01:07 in Robotics
I got my Boe-Bot 2 years ago at a summer camp, and this is the first time I've tried to reprogram it since. Well I have no clue how to find the COM#, I am using the USB adapter if that helps.
Post Edited (LilaLu) : 9/14/2008 9:27:23 PM GMT
    edited 2008-09-14 21:55
    Make sure you have the latest Stamp Editor (www.parallax.com/tabid/441/Default.aspx) because it is better finding the Stamp on the available serial (com) ports. Try doing an Identify. It should search the available com ports by itself for something that looks and behaves like a Stamp. Make sure the Boe-Bot is turned on and has fresh batteries when you do this. You can use the middle switch position to keep the servo motors off.
  • LilaLuLilaLu Posts: 2
    Thank you so much!
