Looking for ADC, I2C & PDIP — Parallax Forums
Mike CookMike Cook Posts: 829
edited 2008-09-15 19:23 in General Discussion
Can someone point me in the right direction?
I'm looking for an ADC with the following:
Interface:  I2C
Resolution: 8 or more bit
Package:    PDIP
# of Pins:  Depends, right now 2 channels would be sufficient, but more is ok
Seems like all that I'm finding are surface mount, I know I need to get with the times and start working with SMT packages!
Thanks in advance!
  • Tracy AllenTracy Allen Posts: 6,666
    edited 2008-09-14 17:36
    Hi Mike,
    There is the venerable PCF8591P from NXP (formerly Philips).
    4 channel ADC + 1 channel DAC, 8 bits, in 16 DIP.
    Tracy Allen
    www.emesystems.com
    edited 2008-09-14 17:55
    SWEET!
    Thanks Tracy!
    And they are in stock at www.mouser.com, can have some by Tuesday.
    I was about to 'dust off' BASCOM-AVR and make my own I2C Slave I/O helper chip out of an ATMEGA chip, saves me a lot of work!
    Thanks again!
    edited 2008-09-14 19:32
    futurlec.com has a lot of Phillips items and odd-ball chips for hobbyist.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
    edited 2008-09-15 18:18
    The PCF8591 is a good chip ifor 8 bits and flexibility. The 4 ADC channels can be configured in different ways for single ended or differential, with span and offset pins, and the channels can be read singly or cycling through all 4 rapidly in one I2C command. Plus the single DAC.
    It seems like so many other companies have licensed and run with I2C, but Philips/NXP is still slowly expanding their I2C product line:
    www.standardics.nxp.com/i2c/
    Tracy Allen
    www.emesystems.com
    The PCF8591 will do nicely.
    Right now single ended will do, and the DAC is a bonus. I can use the DAC for another project ‘in the works’.
    Ordered some this morning and they should be here tomorrow afternoon. I also discovered that Jon has written a couple of Nuts & Volts articles (#79, #85, #115) for the Basic Stamp. This will help getting them working ‘out of the bag’ when the chips arrive. Will need to convert this code for SX/B and Propeller code routines.
    Thanks for the suggestion!
