assembly statement like if_z
Hello there,
My question is related to Propeller assembly conditions.
code Example:
In the first line the code compares two values, if the "dividend" is not lesser the "divisor" the two following lines of code will be executed.
If the "dividend" is less then the "divisor" the the two lines will not be executed. My question is, if the second and the third instruction takes together 8 clocks even if they will not be executed?
Thank you for your answers
Immanuel
code Example:
asmDivision cmp dividend, divisor wc
if_nc sub dividend, divisor
if_nc jmp #asmDivision
Immanuel
If you use conditional execution, the instructions behave as NOPs (no operation) if the condition is false. One NOP takes 4 clocks. Two NOPs take 8 clocks.
One reason to do this is that the timing of a routine can be easily made to be identical regardless of which instructions get executed. This can be done with JMPs, but is harder and more timing error prone.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 9/13/2008 7:43:18 PM GMT
But when I have an instruction like rdlong that takes 7...22 clock cycles, how many cycles will take me this instruction if it will not be executed?
Mr Green said, that all instructions will become nop instruction if they will not be executed, is this right? Then I have different times for the same instruction.
http://forums.parallax.com/showthread.php?p=744614
The definitive answer is on page 368 of the Propeller Manual 1.0; "When an instruction’s condition evaluates to FALSE , the instruction dynamically becomes a NOP , elapsing 4 clock cycles but affecting no flags or registers".
So a 'rdlong' etc will take 4 cycles if it's not executed.
If you want deterministic timing in both cases the best would be ...
rdlong tmp,adr IF_Z mov reg,tmpThis looks good but I bet timing is completely screwed every which way ...
Post Edited (hippy) : 9/14/2008 3:38:13 AM GMT
