Only works few seconds
Hello!
This program only works ok a few minutes.
Some body can tell me why?
Thank you very much.
Sergio.
CON
· _CLKMODE = XTAL1 + PLL8X
· _XINFREQ = 6_000_000
VAR
· long stack[noparse][[/noparse]40]
PUB Principal
· cognew(@terminal, @stack)
DAT
terminal
······· org 0
bucle··mov dira, pin24
······· mov outa, pin24
······· mov time,delay
······· add time,cnt
······· waitcnt time,delay
······· mov outa, #0
······· jmp bucle
pin24 long |< 24
time long 0
delay long 6_000_000
······· fit 496
Sergio.
CON
VAR
PUB Principal
DAT
terminal
······· org 0
······· jmp bucle
pin24 long |< 24
time long 0
······· fit 496
for testing purposes of assembler there are several options... you can simulate the code or you can step through it using one of the multiple options. See here : propeller.wikispaces.com/Debuggers+and+Emulators
All instructions have a source and destination part. The destination is always a position in cog's memory, the source can either be a position in cog's memory (where the value is stored) or the value itself (call literal) when it is between 0 and 511. In the case of the jump, the destination address is known at compile time, so a literal is used, denoted by the use of the '#' symbol. But an indirect addressing mode can be used, denoted by the lack of a '#' symbol, like in your example. Then, it is not working because it is using the value stored at bucle instead of the address itself.
Bienvenido a los foros. De d
Now my error·seems to me·obvious but i spend time enough to turn me crazy
I am from Barcelona, (Spain). Please excuse my poor english.
Thank you again.
Sergio.
propeller.wikispaces.com/Common+Assembler+Bugs
From time to time, that happens,
