Cheap...fast acting...strong actuators...
Hello...I would like to share a discovery with all who deal/need some sort of actuator.
In the process of developing a braking system for Robo Caddy, I was looking for a 12 volt actuator to engage some brake shoes to slow Robo on a downhill or act as a park brake.
Anyway, I Googled actuators, and discovered door lock actuators from cars.· That's right, go to Ebay and search for door lock actuators.· They are cheap, and very strong.· Reversing the feed wires will reverse the operation of the actuator.· Will pull in or push out depending...One thing, you cannot leave 12 volts on them continuiosly.· Pull in or pust out, then disconnect the voltage.· These things are strong, and you get about 1 inch of movement of the plunger...in or out.
I just bought 2 of them, to test, and will be using them.· One to activate the brakes, and the other one will release the brakes.
Deno
Post Edited (deno) : 9/12/2008 1:20:53 PM GMT
Deno
John Bond
I was going to ask if you could test how much force you get from these?
There are so many great resources that can be found in our junkyards these days. The other gem I love, and yet to use, is windshield wiper motors. That is on my list...
Please keep us updated!
-Parsko
Tim
