HUB Memory Space Re-Use
Brian Fairchild
I'm evaluating (=playing with and having great fun with) a propeller with an eye on using it in a commercial product. At the same time I'm trying to unlearn 30 years of experience on other micros...
The scenario...
All 8 COGs used, COG 0 runs the master controlling SPIN code, the other 7 COGs run assembler programs handling I/O etc. Now, once the system is running the space in the hub ram initially occupied by the seven 'starts' and their associated (up to 512 longs) assembly DAT sections is not needed. Is there a clean way to reclaim and reuse that space for data buffers?
The scenario...
Read this thread
http://forums.parallax.com/forums/default.aspx?f=25&m=292400&g=292925#m292925
Nothing is impossible, there are only different degrees of difficulty.
Sapieha
This thread will probably be more useful to you: http://forums.parallax.com/showthread.php?p=670353
Michael Park
PS, BTW, and FYI:
To search the forum, use search.parallax.com (do not use the Search button).
Check out the Propeller Wiki: propeller.wikispaces.com/
