Could use opinions on motion and positioning options
What is the best method for accurately homing a linear motion project on power up? I have broken several fixed switches on CNN machines, so I tend to want to avoid physical switches that are in the 'path'. I am looking for a tolerance of 1/32" or less accuracy on every power up when the machine homes automatically. Reed switches? Hall sensors? LED? It is not a CNC machine, so extreme precision is not required.
I have one pin available on the Prop with a pullup, so that grounding a switch (switches) on each end of travel sets the limits. An encoder tracks things from there.
Any suggestions welcome.
- Stephen
The object being moved weighs over 100 lbs, so there is very little forgiveness on the switches if they are in the path.
In a perfect world, the motor would stop at the point of contact, but in reality the object will be slid around often even when power is off, and the motors and controller are not even on, rubber stops are required to prevent to hard an impact.
For these reasons, I want something non destructive, so that should the object slam against the stops, the switches survive. The optical slot sounds interesting, I will google it up.
like these
'Still some PropSTICK Kit bare PCBs left!
