low level detail on case — Parallax Forums
Erik FriesenErik Friesen Posts: 1,071
edited 2008-09-11 04:16 in Propeller 1
How many time does a variable get checked in one case statement?
For example does variable get checked once or three times in the below code?
case variable
   "a":do
   "b":dontdo
   "c":doorelse
  • mparkmpark Posts: 1,322
    edited 2008-09-10 23:41
    Not sure what you mean by "checked", but the case expression (in your example, just variable, but it could be more complicated) is evaluated once; the result of that evaluation is compared up to three times (against "a", "b", and "c" -- but of course if it matches "a" it won't keep comparing).
    Michael Park
    PS, BTW, and FYI:
    To search the forum, use search.parallax.com (do not use the Search button).
    Check out the Propeller Wiki: propeller.wikispaces.com/
    Post Edited (mpark) : 9/10/2008 11:50:40 PM GMT
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2008-09-11 01:31
    Right, but if the variable changes between comparisons it still uses the original, right?
    edited 2008-09-11 02:15
    Im 95% certain there is only a single evaluation of "variable".
    Paul Baker
  • hippyhippy Posts: 1,981
    Paul's correct. Once the particular choice to use has been selected the code associated with it is executed and then the entire case is over and done with.
