I2C Timer Thingy? SDA\SCL
Ive got this board, it had gotten wet and the CR3032 battery in the timer was dead when I got it. I cant get it to accept programming, its not writing it to the Serial EEPROM, im not sure if the external timer is neccessary for it to work or not, but im pretty sure there is a problem in the timer regardless.
With a scope on the SCL and SDA lines, with power off to the board (battery in) I get nothing.
When I power the board I get exactly·3.4 volts, no oscillation, no movement. VCC is 3.3 volts, thats a little odd.
I dont know anything about IC2, but im assuming this is supposed to be some kind of timer.
Where should I start? I have checked the crystal, it is oscillating.
http://myfiero.com/uploads/13808_.jpg
Post Edited (GICU812) : 9/10/2008 4:13:19 AM GMT
Should I be getting an output on the lines, or is this more of a slave device I have to signal to get it to talk?
I was thinking at first that it should be outputting a clocking signal, but the more I think about it, maybe thats the case.
Anyone with more information on IC2 it would be appreciated.
The datasheet describes how to talk to the IC (I assume you mean IC2 is U6. If not, you need to explain better what you've got and what you're trying to do).
In sum, this is an outboard clock module that requires a microcontroller as its master.
Wikipedia for I2C will provide you with an introductory summary. Also, the BasicStamp Manual has a very good presentation of how to use I2C.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
