Acoustic coupler schematic needed
I plan to use BS2's DTMF for some portable data communication and started looking for methods of acoustically interfacing such devices.·There used to be quite a few acoustic coupler designs in the past but with "all cellular"·they seem·to vanish.·
As I plan to investigate this old method·I'm in search of old·Tandy - Model 100 acoustic coupler schematic (or any 300 to 2400bps acoustically coupled modem's schematic).
Perhaps somebody has such a schematic and can attach an image·of it here... or point out where to find one.
John
Post Edited (john_s) : 9/10/2008 5:19:16 AM GMT
John
So, you might consider using two small laptop speakers. I have one here that is 8ohm and .4 watt. Added to that would be a good amplification chip for output side and maybe a multiple op-amp chip to filter noise on input side and to increase the input to digital levels.
Try SXList.com or Senix-Ubicom to search for example circuits using the SX-28 chip. They would probably be in modem designs.
You could easily do a direct wiring rather than bother with creating an audio link. There certainly are examples of that. I have a few printouts on file. This SX-28 is the same chip used in many of the newer BasicStamps. The most powerful use the SX-48.
I really suggest you forget the audio link and create a hardware link for an RJ plug. These days, it is more awkward to cradle the handset as standard sizes have all but disappeared.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
