Maths problem Cosine
How do you convert a cosine number into an angle with a basic stamp BS2e
The maths function is Inverse Cosine or arc cosine (acos) for example
The COS of 80 degrees is 0.17365
So if I have the number 0.17365 I want to convert it back into the angle 80 degrees
www.emesys.com/BS2math3.htm#arcCos
The Stamp uses integer math for everything, and angles and fractional lengths are no exception. 0.17365 will be 22 on the Stamp, because 22/128 = 0.172. Full scale is -127 to +127. Angles are in brads, 0 to 255 for a full circle. It is not very precise, but okay for some applications.
Tracy Allen
www.emesystems.com
Use the force. Stick with the Stamp. This online forum is the most amazing resource of friendly, educated, and helpful people I have ever found. You'll find useful workarounds for any features the Stamp may lack.
e.g.
Post Edited (Zoot) : 9/10/2008 12:32:41 AM GMT
