Need help regarding memory access
Not really sure where to go with my problem so i thought i would come here ha...
My situation is this. i have an old digital camera that i would like to hook to a robot but i would rather not have to program it to navigate through menus and settings through the buttons in order to pick settings/shoot modes etc. i would rather it be able to call for these modes directly.
The solution that i see is to access the firmware in the camera and change it as needed to allow a program i write to activate the different settings.
is the the best/easiest solution? if so how do i download the firmware and edit it. if not what would be best
(i have data sheets for the two different memory IC's in the camera)
or if you know of a place/forum where i could go that is better suited for answering that would be great.
In some cases, you can simplify your task and use a device quite well. In this case, try to figure out which setting are most useful and provide them manually. I have a box that holds my digital camera and uses a BasicStamp with a servo to snap the picture. It is very simple and it merely allows me to set a cycle of how often the photos are taken. I can also include a light sensor so that it turns off during the night or periods of poor lighting to conserve further batteries.
This might be a better approach if the manufacturer won't share its trade secrets.
Of course, every now and then a manufacturer will provide a product that is open architecture and these become hugely popular. You might look for such a camera.
Right now I am playing with an Asus WL500-gP Wireless Router that the firmware can be completely replaced with Linux. It is really a joy when these devices sudden appear. For less than $100USD, I got a router that can do backflips usually supported by a $600 device. I can even have a USB hard disk connected and create a website that is up 24/7.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
alrighty, thanks for the response.
One day you might want a different photo project. Years ago I worked on a rock concert with a sound tech that took all his own stereo 3-D photos by building his own mounting bar for two Insta-matic cameras. He used a 1920 viewer and the pictures really were quite good, full color 3-D.
The same can be done with two digital cameras. Sure it is easier if you have a pair of the same type, but it is not absolute. You just have to have them take the photos at the same time with similar settings and mounted with a proper angle between them.
